Item Posts
Sort Order
j20 8 lug 15" wheels???
Posted: 02/20/08 08:27 PM
ok, so i have found a pair of 8 lug jeep j20 axles. the front is a dana 44 and the rear is dana 60 with disc brakes from a dana 70 im told. i have been searching online for hours with no avail for some 15x10 rims that will fit these axles. am i on a wild goose chase?? if you would drop me a line at elyria_boy@yahoo.com it would be appreciated.
K.McNulty
New User
Posted: 02/22/08 06:07 PM
You very well may be on a wild goose chase! Is there a reason you want to run 15-inch wheels with these axles? Is it the jump in tire price? I would recommend looking around for some 16.5-inch wheels. The larger wheels will clear the calipers of your axle’s disc brakes better. If you find and use use a 15-inch wheel on these axles you may have to shave your calipers. This is something that can be done but we don’t recommend. Pro Comp sells economical 16.5-inch steel wheel with an 8-lug (8x6.5) pattern. www.procomptires.com/series51.htm
I hope this helps?
K. McNulty
Kevin McNulty 4Wheel Drive & Sport Utility Magazine kevin.mcnulty@primedia.com
Posted: 02/23/08 01:18 AM
yes, thanks for the help. i just happened to find a deal on some tires and some axles and just trying to find hte best way to use them both. im on a budget and this is my first build, so i know there is going to be unforseen dificulties but i think with what i have read and what everyone has posted and sent that i should have it figured out.
78floyd
New User
Posted: 03/18/09 07:50 PM
I have a 78 jeep cherokee that I put a dana 60 and a 14 bolt in. I put 15 inct wheeles with 4 inch offset wheeles and miner grinding of the calpers. afterwards I found out that you dont have to use such an extreem offset but you will have to grind the calipers some more. good luck with your new axles.
Posted: 12/30/11 10:33 AM
You may have wheels by now but if not Discount tires can get offset wheels for you at $69.00 ea. 8 lug by 15" 10" -12" wide offset
Posted: 05/19/12 09:37 PM
Nationaly Tire and Wheel makes custom steel beadlocks in pretty much any size you want. The brand is Eaton. They have a website: NTWonline or something like that, though it would probably be wiser to call them..
My bumper sticker says "NOT A HIPPIE JUST A WELL GROOMED MOUNTAIN MAN" LoL
Posted: 08/27/12 10:45 AM
Check this site as well: http://www.wheelsanything.com/
Posted: 09/30/12 07:43 PM
i have some 15x10 8 lug wagon wheels if you are intersted i can ship them
