Weber Whistle - 4Wheel & Off-Road Forums at 4Wheel & Off-Road Magazine 4-Wheel & Off-Road
Facebook Newsletter
Weber Whistle
User Name:
Password:
Join FREE Now!
Forgot Password?
Forgot User Name?
Remember Me
Get Adobe Flash player
Home | Active Posts | Search | Register | Terms | FAQs
Rss
Item Posts    Sort Order
Weber Whistle
VuDu66 VuDu66
New User | Posts: 6 | Joined: 03/11
Posted: 11/11/11
10:58 AM
I have a '90 Wrangler with a 258ci. I have a Weber 34/36 DGEC installed on it about a year ago. I has be running great til about 2 months ago I started hearing a whistle, I open the hood and could hear it coming from the carb. I looked for loose hoses, vacuum line and found none. This whistle is happening at idle and while driving, but it is not happing all the time. I just did a rebuild kit on the carb and I still have the whistle. There are no lose hoses or lines. Any ideas??
binderbird binderbird
New User | Posts: 21 | Joined: 07/09
Posted: 11/12/11
12:49 PM
Sounds like the carb gasket. Replace the gasket under the carb to intake and torque it to spec.
VuDu66 VuDu66
Posted: 11/15/11
09:46 AM
I did that and still have the whistle.
KidCurry3 KidCurry3
New User | Posts: 3 | Joined: 09/12
Posted: 09/10/12
11:13 PM
You most certainly have a vacuum leak. Start up the motor and spray around the intake and the carb and when the idle jumps up you will find the leak. I have an 89 yj 4.2 carb with the weber, I have the same issue and I found I need to replace the intake manifold gasket and the carb baseplate gaskets are leaking.
mechanical1dr mechanical1dr
New User | Posts: 39 | Joined: 02/11
Posted: 09/15/12
06:45 PM
Check to see if it is coming from the PCV.
