Item Posts
Sort Order
Weber Whistle
VuDu66
New User
Posted: 11/11/11 10:58 AM
I have a '90 Wrangler with a 258ci. I have a Weber 34/36 DGEC installed on it about a year ago. I has be running great til about 2 months ago I started hearing a whistle, I open the hood and could hear it coming from the carb. I looked for loose hoses, vacuum line and found none. This whistle is happening at idle and while driving, but it is not happing all the time. I just did a rebuild kit on the carb and I still have the whistle. There are no lose hoses or lines. Any ideas??
Posted: 11/12/11 12:49 PM
Sounds like the carb gasket. Replace the gasket under the carb to intake and torque it to spec.
VuDu66
New User
Posted: 11/15/11 09:46 AM
I did that and still have the whistle.
KidCurry3
New User
Posted: 09/10/12 11:13 PM
You most certainly have a vacuum leak. Start up the motor and spray around the intake and the carb and when the idle jumps up you will find the leak. I have an 89 yj 4.2 carb with the weber, I have the same issue and I found I need to replace the intake manifold gasket and the carb baseplate gaskets are leaking.
Posted: 09/15/12 06:45 PM
Check to see if it is coming from the PCV.
